Failed to find an IPv4 address on an interface. All-multicast mode will not be enabled on the interface.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Did not find IPv4 address on i/f %p1%. Cannot enable all-multicast mode.
| Name | Type |
| p1 | uInt32 |
